Rack and Pinion
Old Apr 21, 2003 | 11:55 PM
orange68's Avatar
Rack and Pinion
I am planning on putting a manual rack and pinion system in my car. I want a quick as possible ratio. The only one i could find under 3.75 turns is the steeroids kit but i do not want to go that route. All i want is the rack for now and i will get to the shafty buisness later. I was wondering if anyone knew if it mattered weather the rack was mounted in front or behind the crossmemeber? I was thinking of the flaming river mustang II but i dont know exacty what the difference between that and the wilwood pinto, all i can tell is that there are mounting holes on the mustang II unit. I have been looking at alot of different sites and they are all confusing me even more. if anyone has advice for me please let me know. Thanks
Old Apr 22, 2003 | 07:06 PM
orange68's Avatar
oops
i just realized how silly one of the things i said was. Of course it matters if its infront or behind, disregard that question. Does anyone know of a rack i can buy that is rear steer?
Old Apr 23, 2003 | 07:50 PM
texlurch's Avatar
By using the steering arms off a Chevelle, you can switch it to a front steer. I had a Pinto rack on my 68 for a while, but even after shortening it, I could not get rid of the bump steer. I think if I had cut a couple more inches out, it would have been better.
I don't think the Mustang II rack will fit behind the crossmember without some surgery, but I haven't measured it yet. It will also need to be checked for angles to eliminate bump steer. I wonder if anyone here is using the Steeroids kit and can comment on how the bumpsteer is? They sell a manual setup also I am pretty sure.
If you want a quicker box, get a later model (mid 80's) Z28 or Monte Carlo SS. They are around 3 turns lock to lock and can be adapted easier than the rack and pinion.
Old Apr 25, 2003 | 11:35 AM
dust6928's Avatar
i read somewhere that you can take the guts out of a mid-late 80's camaro steering box and put them into the 1st gens housing with no trouble. and it is a little less than 3 turns i believe.
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
97blackformula
Aug 27, 2015 06:02 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
