pre 87 heads with LT1 headers
Old Jan 16, 2004 | 10:34 PM
JDBlaze85's Avatar
Does anyone know if LT1 headers will bolt on to an engine with pre 87 sbc heads? are the exhaust ports the same?
Old Jan 17, 2004 | 12:45 AM
FiefSS's Avatar
I would imagine they would, i think 4th gen lt1 heads are basically same except for the internal parts like the water passages. It is possible they would fit, but headers are more expensive I believe. Good set of hooker comps or super comps for a regular small block might be better
Old Jan 17, 2004 | 02:45 AM
JDBlaze85's Avatar
I wanted to go with LT1 headers since I am putting this engine in a 97 Trans Am. I would figure they would clear the engine bay just like an LT1 would. what do you think?
Old Jan 17, 2004 | 05:22 PM
FiefSS's Avatar
that is a good idea then I would think though that they would.
Old Jan 23, 2004 | 05:02 PM
442olds's Avatar
LT-1's have an extra hole at the front and rear of the head. This hole was added to most all 87 and newer heads and some pre-87 heads. If the headers were created to follow the stander lt-1 exhasut bolt pattern it will use these extra holes rather than the hole right next to the #1 and #8 ports. So at most you may have to drill two new holes, one in each header. it would be best to check this before sticking everything in the car.
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
