Power Steering Bracket
Old Jul 6, 2005 | 11:28 PM
rwjohnson06's Avatar
I have a 1980 Camaro and am in need of a new power steering bracket and have had no luck in finding one anywhere. The motor is a 350 in. Crate engine from GM Goodwrench. Heres some more info on the engine i have. http://www.crateenginedepot.com/stor...29-P824C2.aspx
Old Jul 12, 2005 | 05:40 PM
Re: Power Steering Bracket
3 Days and no responses...?
Old Jul 12, 2005 | 06:18 PM
angel71rs's Avatar
If you can't find it at junk yard, try my #2 source for stuff like this, ebay. Search using the words "steering bracket 350" and I'm sure you'll get a couple of hits. BTW, it doesn't have to be off a Camaro or a 350. Nova, impala, 350/305 brackets are usually the same. Just eyeball the pics and see if it's what you need.
I scored a manual box with the pitman arm for cheap on ebay. I was only bidder. These boxes usually go for 75-100 on the boards, + another 30 for the arm. I think I got them both for 35. I wanted them in case I ever want to unleash the 10hp or so the power steering sucks up.
Old Jul 13, 2005 | 12:32 AM
Okay, Thanx man. Ive searched only 1 junkyard, locally and have had no luck with finding any camaros with engines in the and ive got a buddy over by me that has a 454 in his 1984 chevy 1 ton pickup that has the same bracket and power steering unit as my car so yeah, there is a wide range of choices i could in getting this bracket.
Old Jul 13, 2005 | 01:54 AM
70modelz28's Avatar
cant you still buy the bracket new?
Old Apr 26, 2006 | 01:12 PM
At least not from any local car parts store (autozone, pep boys, kragen).
Old Apr 26, 2006 | 10:30 PM
firebird69racer's Avatar
the 454 bracket I dont think will be the same
most any 1980 Chevy will use the same bracket as long as its a small block
Wade
Old Apr 26, 2006 | 11:18 PM
markinkc69z's Avatar
March has one for a saginaw pump.
HectorM52
Jul 30, 2017 11:46 AM
mspennyhughes
Mar 1, 2015 03:50 PM
