pontiac ?
Old Mar 30, 2004 | 03:29 PM
anuarism's Avatar
pontiac ?
So what is the difference between a pontiac 400 and 455, bore or stroke or both?
Old Mar 30, 2004 | 07:38 PM
2000zee28's Avatar
455
Engine Code WT, WW, ZZ, ZE
Engine RPO L75
Displacement 455 CID
Bore x Stroke 4.1522" x 4.121"
Compression Ratio 7.6:1
Horsepower @ RPM 200@4000
Torque (Lb/Ft) @ RPM 330@2800
Head Casting 7F6
Carburetor 4-bbl
Carburetor - Federal 7043273
Camshaft
Part #
Lift, I/E NA / NA
Rocker Arm Ratio 1.5:1
Duration I/E - Degrees NA / NA
Overlap - Degrees NA
Intake Valve Dia - 2.11"
Exhaust Valve - Dia 1.66"
400
Engine Code WT
Engine RPO L78
Displacement 400 CID
Bore x Stroke 4.1212" x 3.750"
Horsepower @ RPM 185@3600
Torque (Lb/Ft) @ RPM 310@1600
Head Casting 5C
Carburetor 4-bbl
Carburetor - Federal 7045263
Intake Manifold 495106
Camshaft
Part #
Lift, I/E .377 / .415
Duration I/E - Degrees 269 / 282
Overlap - Degrees 59
Old Mar 31, 2004 | 01:03 AM
IRONFIST's Avatar
you can stroke a 400 to 455.. so not much
Old Apr 1, 2004 | 05:55 PM
Dave89IROC's Avatar
you can take a 400, bore it .030 and use a 455 strock crank
Old Apr 2, 2004 | 09:32 AM
quicksilver97ta's Avatar
Both. But you can't just drop-in a 455 crank, they have a larger main journal size than the 400. Go check out "pontiacdude.cc" lots of cool pontiac build-up stuff.
Old Apr 2, 2004 | 02:18 PM
Dave89IROC's Avatar
I meant to say 455 stroke crank, I knew the mains were different
HibachiZ28
Nov 6, 2015 12:53 AM
Hal Fisher
Sep 30, 2015 09:03 PM
smoknta
Aug 27, 2015 05:07 PM
Jul 17, 2015 02:47 PM
whuzizname
12
Jul 22, 2002 07:52 PM
