Not starting after 4 months
Old Apr 8, 2003 | 06:09 PM
68SuperRam's Avatar
I tried to start my car - after 4 months - and it won't start - I get a spark out of the coil - blaster 2, but not at the plugs through the HEI distributor? I have yet to take the cap off and look around - but any ideas. As my bio says - I have the Accel Super Ram kit, but I don't think that it is electrical, as the coil is getting a signal from the HEI distributor to generate a spark.
Burnt rotor, cam not spinning? I do not use the car that often to burn the rotor.
Any ideas?
Old Apr 8, 2003 | 09:14 PM
CoryM's Avatar
I would verify that the rotor is working and all is well under the cap. You have a external coil? If so take a close look at the cap and the coil wire. If the car ran fine when you parked it I would also look for moisture under the cap and clean it out with some wd-40. Im sure there is more to check but my head is all wore out from work today . Keep us posted
CoryM
Old Apr 9, 2003 | 12:36 AM
jg95z28's Avatar
Yeah I agree... check for moisture under the cap.
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
NewsBot
Dec 3, 2014 12:30 PM
