new connecting rod nut?
Old May 15, 2007 | 10:57 PM
DiabloGT's Avatar
i lost one nut from the connecting rod on the 455 while doing my engine rebuild. is there any place i can buy one or a set from?
thanks
Old May 17, 2007 | 09:24 AM
angel71rs's Avatar
Whenever I need a stray part for an engine, I call the machine shop I like to use. They'll usually have a rod, cam dowel, or single set of rings for one cylinder, etc, laying around. You can also see if a large wrecking yard has a pile of busted engines headed for scrap, maybe there's an Olds in there you can cannibalize. Or go to realoldspower.com and see if anyone on that board has a nut they can let you have.
Old May 17, 2007 | 03:23 PM
Damon's Avatar
Yeah- local machine shop is your best bet. They often end up with extras of various parts laying around. Con rod nuts are similar between many different engines and manufacturers. Chances are one off a common Chevy, Ford or some other motor will work on your Olds rods.
Victor Lamb
Aug 26, 2017 02:52 PM
KamikaZ28
May 28, 2015 12:45 AM
Jul 4, 2005 05:00 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
BIGCOWL-IMP
Jul 22, 2002 04:28 PM
