massive blow by
Old Dec 20, 2004 | 01:31 AM
amean94ta's Avatar
massive blow by
ok its a ford 87 5.0 I took off the valve cover to throttle body hose off cause it was filling the intake with oil then i noticed all the oil/smoke pouring out so i capped it off wrong thing to do it pressurized the valve covers and blew the gaskets out now it leaks on the headers anyway it never smokes out the tailpipes what is this and how to stop it
Old Dec 20, 2004 | 10:31 AM
MaxHarvard's Avatar
Re: massive blow by
Replace the valve cover gaskets, put some good RTV on it, and then replace the PCV valve with a new one, and replace the grommet as well... put the vacuum hose back on and that should solve your problem.
Old Dec 20, 2004 | 10:42 AM
amean94ta's Avatar
Re: massive blow by
i know the gaskets. but its a pcv valve..... wait it does not have one just a straight hose from filler to tb. just put on inline? and are they all the same? also this will stop the oil filling up the t/b?
Old Dec 20, 2004 | 10:45 AM
MaxHarvard's Avatar
Re: massive blow by
They are not the same, and yes it will stop the oil filling up the throttle body, thats what a PCV valve does. if the insides break down you will start filling the throttle body. Make sure you get the right PCV for your car, otherwise it wont fit. And yes, all you need is a vacuum line from the PCV to your T/B
Old Dec 20, 2004 | 11:59 AM
amean94ta's Avatar
Re: massive blow by
thanks
Old Dec 26, 2004 | 10:07 AM
LandryP's Avatar
Re: massive blow by
My friend had the same problem with the 5.0 in his crown vic, If I remember correctly the hose itself for the pcv was clogged and caused the the crankcase to pressurize and blow out the valve cover and oil pan gaskets
Old Dec 26, 2004 | 12:23 PM
amean94ta's Avatar
Re: massive blow by
yeah i guess the mustang guys i talked to also have this problem but they run hoses down to the headers and tie them in there to exit through the exhaust
magman
Apr 15, 2016 03:08 AM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
350350
14
Aug 11, 2015 12:03 PM
