lowering rear of 67 camaro???????
I have a 67 camaro that has new rear mono springs and now needs to be lower in the rear what seems to work the best with out ugly sackles?
Thanks for any info
Thanks for any info
I would opt for replacing the spring over having a Mono-leaf re/de-arched. You can acquire a different spring rate as well as changing the ride height, from doing this.
Another option is using lowering blocks, but I would not recommend their use of more than an inch (2.54 centimeters).
oldschool
Feb 9, 2016 09:21 PM
