lifter difference
Old Mar 9, 2005 | 02:53 AM
rhino38's Avatar
lifter difference
solid and hydraulic,whats the difference? why couldnt you use hydraulic lifters with a solid cam?
Old Mar 9, 2005 | 07:18 AM
Capn Pete's Avatar
Re: lifter difference
Solid cams are built with steeper, more aggressive ramps than hydraulic cams. If you ran hydraulic lifters on a solid cam, you'd probably risk floating valves, or it may cause damage to the cam/lifters if they can't maintain proper contact during operation. I don't see why you couldn't use solid lifters on a hydraulic cam though?
Old Mar 9, 2005 | 09:01 AM
rskrause's Avatar
Moderator
There are different opinions on using a solid lifter on a hydraulic lobe. I have done it with no problems but it was a matter of necessity at the time and wouldn't do it by choice. Some of the newer hydraulic lobes are just about as steep as the solids. Comp Cams XE lobes come to mind in that regard.
Rich
Quickss96
Jan 29, 2016 05:56 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
97SSdude
Aug 21, 2015 09:36 AM
whitehooptie
Aug 10, 2015 07:02 AM
