Just having fun, theoretical engine build.
Old May 4, 2007 | 06:58 AM
Speed Demon 505's Avatar
My Idea of a KILLER STREET ENGINE! 377 SBC
Short Block
-Dart Little M block 4.155 bore + splayed mains + head and cap studs +1 piece rear main
-Eagle forged Crank
-Eagle H-Beam Cap Screw 6.125 Rods
-JE Forged +5cc
-Total Seal Gapless Rings; Top Ring Thickness: 0.043 in.
Second Ring Thickness: 0.043 in.
Oil Ring Thickness: 3.0mm
-Clevite 77 bearings
Valvetrain
-Cam...Lunati VOODOO
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 2,800-7,200
Intake Duration at 050 inch Lift: 249
Exhaust Duration at 050 inch Lift: 255
Duration at 050 inch Lift: 249 int./255 exh.
Advertised Intake Duration: 279
Advertised Exhaust Duration: 285
Advertised Duration: 279 int./285 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.585 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.600 in.
Valve Lift with Factory Rocker Arm Ratio: 0.585 int./0.600 exh. lift
Lobe Separation (degrees): 110
Camshaft Gear Attachment: 3-bolts
Intake Valve Lash: 0.016 in.
Exhaust Valve Lash: 0.016 in.
-1.6 Crane Cams Roller Rockers
-AFR Hydra Rev Kit
TOP END
-AFR 210cc Eliminator Lumi cylinder heads
-Holly 815 CFM Blow through Carb for S/C
-Brodix Single Plane 3500-7200 rpm manifold
-Vortec 6-8 PSI Supercharger
Oil System
-Dry Sump
-Windage tray and 2 crank scrapers.
-Crankcase evacuation system: 2 Doyle valve/header evac line
So what do you desktop dyno guys think this would produce? Anything to change? Any parts you would better recomend? I was just toying with the idea personally, but It would be a $10,000 budget for the S/C and $6,500 for the N/A.
Old May 4, 2007 | 10:49 PM
rhamm1320's Avatar
[QUOTE=Speed Demon 505;4582192]So what do you desktop dyno guys think this would produce? Anything to change? Any parts you would better recomend?[QUOTE]
Looks good to me, I sure wouldn't kick it out of bed
Old May 7, 2007 | 01:37 AM
Oh my god.... Its on. Thank you, thank you, thank you. I need one of those programs so bad. haha
Old May 7, 2007 | 08:11 PM
RAT454's Avatar
alloy BBc
Merlin-X aluminum BBC block
Deck Ht. 10.200"
Bore 4.5
Billet Steel Splayed Main Caps
Merlin III Aluminum Big Block Chevy Rectangular Port Cylinder Heads
Manley Severe Duty 2.30 intake 1.88 exhaust
Rect port intake 350cc runners, 119cc chambers
Lunati rotating assembly
4.750 stroke
H beam rods
Forged pistons
CR 10.75
Comp Cams HYDRAULIC ROLLER-.
XR288HR 288/294 236/242 .521 .540 110° L/S,
Comp Cams Roller rockers, push rods, springs retainers etc…
Merlin Single Plane Competition intake
Deck Height10.200"
Carb4150 1150 barry grant carb
Mildon gear drive, Fluid dampner, MSD Ignition, Hamburger oil pan,
Victor Water pump
604 ci 700/700
Just for fun
G
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
hotrodyou1
Dec 20, 2014 10:05 PM
