Stock block limits?
Old May 1, 2007 | 04:22 PM
mdenz3's Avatar
Stock block limits?
My friend is planning a build on a mid 70's 4bolt 350 block. His goal is about 450fwhp then spray the ***** out of it. We are unsure of just how much the block wil like though. Anyone know at about what level factory blocks start to come apart?
Old May 1, 2007 | 09:20 PM
rhamm1320's Avatar
At the N/A 450 HP, he is probably ok. Add the N20 and he is on his own - depending upon how much nitrous he uses, it probably will not last long.
Old May 2, 2007 | 11:13 AM
LesPaulGoth's Avatar
What is the rotating assembly that will be used? I would think that they would go before the block would, especially if it is a 4 bolt main.
Old May 2, 2007 | 02:35 PM
mdenz3's Avatar
He is planning on a forged Scat rotating assembly.
Old May 3, 2007 | 12:40 PM
Steve69SS396's Avatar
He should be fine. I'm running a '71 4-bolt block with stock caps and stock forged crank. Based on my ET and speed it's putting 580+HP to the tires. This motor was originally built in '98 and it's still going strong.
He will need a good rotating assembly and studs on the mains.
Old May 4, 2007 | 05:31 AM
Speed Demon 505's Avatar
Oh yeah man he will be fine. A stock Chevy block is good to 850 hp before danger . Right about now he should be feeling fortunate he isnt a Ford guy, the 302s split in half at 500 hp
Old May 4, 2007 | 10:52 PM
rhamm1320's Avatar
Reminds me of one of my favorite Ford quotes by my old boss.
"One good thing about a Ford, the engines never make enough power to really hurt themselves if they blow"
Old May 10, 2007 | 07:42 AM
71Z's Avatar
71Z
I'm rwdyno'ing at 514 hp with a stock 010 block (355) with no problems.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
MustangEater82
19
Sep 3, 2002 02:09 PM
