Ignition stuck 1979 z28
Old May 4, 2013 | 11:28 PM
z28black's Avatar
Hi all - 2 weeks ago was able to turn key but battery basically dead. After hooking up battery cables to jump start, went to start, and ignition will not turn past acc. to crank. I've turned wheel back and forth, tilt wheel up and down, cussed, prayed, hopped on one leg while whistling dixie, to no avail! I've also moved shifter from N to P and back and forth. So, went ahead and removed steering wheel to replace ignition cylinder, and have same problem. It is the mechanism that the lock cylinder attached to in the column that appears jammed. Any suggestions for a fellow Zer? Thank you in advance.
Old Jun 10, 2013 | 07:13 AM
mikefox's Avatar
Re: Ignition stuck 1979 z28
Maybe you should check the carburetor of the engine. It might have got choked or something. Just get it checked and cleaned up. Hope it all gets fine.
Old Jul 1, 2013 | 11:05 AM
Gee..... Mike. You indicate you are from Tustin, CA.... but your IP address is from Mumbai, India. Isn't this a bit odd?
Old Jul 8, 2013 | 02:17 PM
4586's Avatar
Darn Injuneer...he got banned before he explained how the carburetor (if it even had a carb) was connected to the steering column lock
z28black: Just guessing..but I would check the switch half way down the column...a rod runs from the key switch to that switch..the rod that moves up and down may be jammed or the switch came loose.
Ed
chstitans42
May 1, 2015 01:03 PM
Dzmaro
Jan 25, 2015 10:39 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
tds1213
Nov 27, 2014 12:55 PM
Brent94Z
Mar 21, 2002 04:44 PM
