How much power should this combo make
This is my engine specs that will be going into the 67 camaro. Just wondering how much horsepower do you think this combo will throw down.
355 sbc
dart 200cc iron eagle heads.63cc chambers
10.6 compression
speed pro hyperutic pistons with teflon skirts
eagle cast crank
eagle sir i beam rods
solid comp cam 532/555 lift 106 lobe @ .50 250/260
355 sbc
10.6 compression
eagle cast crank
Re: How much power should this combo make
somewhere around 400-450hp
I have a similar set up , hydro roller cam though though, it is around 440hp
Originally Posted by stale
Sounds a lot like the 383 I've got on project. In fact, the bottom end is identical. Desktop Dyno says I'll be rocking 460hp/450tq.
Desktop Dyno is usually high on HP and torque, but in the ballpark if all inputs are accurate
Originally Posted by Dave89IROC
can't be identical, his is a 355, not 383
The inputs are as good as I can get them. I scammed a .flw file for the specific set of heads I'm using and a .cam file for the Comp cam I plan on picking up. I'd guess I'd be somewhere in the ballpark of what it says. Plus, Dyno 2003 seems a lot more reasonable on numbers than Dyno 2000. Dyno 2000 had this 383 making over 500hp, which is obviously wrong.
I've seen lots of stuff on Dyno 2000 that either seems too high or too low. Lots of people say that DDs estimate for my motor is low. DD 2000 came up with 360hp/450tq for my 400:
Stock shortblock, Aluminum L98 vette heads w/mild work, .490/.490 230/236 110LSA, performer intake, non-CC q-jet, approx. 9.5:1 compression
Lots of knowledgeable people tell me that combo should be worth closer to 400hp, but I just keep saying we'll see what happens when the car is together on the dyno and the track.
- Justin
- Justin
- Justin
- Justin
stock shortblock, but not stock from the car............
So, that being said, what is the bottom end? 350? Cast or forged? Etc...
To correct my previous statement:
The block, crank, rods, and pistons are straight from the factory, and to the best of my knowledge, have never been apart.
I pulled the 400 from a '77 Blazer, but the motor was pulled from an unknown source before it ended up in the Blazer.
The bottom end is all stock, and hasn't been taken apart. When I tore the motor down everything looked to be in good shape, so I didn't bother with a complete rebuild due to $$$. The guy I bought the motor from said that it only had about 80k miles on it, and from looking everything over, I'd say that is a pretty close estimate.
It should hold up fine for a few years of cruising and weekend drag racing, till I have the money to have the bottom end built up correctly
- Justin
- Justin
F'n1996Z28SS
Aug 23, 2023 11:19 PM
