How to clean and Prep Block 4 paint?
Old Jan 10, 2006 | 12:19 PM
Deenasty's Avatar
What are you guys using to clean and prep the block for paint? Thanks guys!
Old Jan 10, 2006 | 01:27 PM
angel71rs's Avatar
Re: How to clean and Prep Block 4 paint?
I like to put it on the stand and wash it with warm soapy (laundry detergent) water. Then blast it with high pressure water in every nook and cranny, then blow dry it with compressed air. I apply atf to all machined surfaces with something lint free, my favorite being table napkins. Then I wipe down the surfaces to be painted with thinner or carb cleaner, dry with compressed air, then mask off and paint. Make sure and mask off the pad where the starter bolts on.
Old Jan 10, 2006 | 01:31 PM
Deenasty's Avatar
why do you apply atf to all the machined surfaces?
Old Jan 10, 2006 | 01:40 PM
angel71rs's Avatar
Atf protects them, keeps them from rusting.The cylinder walls of a freshly machined block are particularly succeptible to instant rusting.
Old Jan 11, 2006 | 10:28 AM
stale's Avatar
Yup, ATF works good and if you need to store the block, that STP oil treatment (motor honey) is awesome. I have a block that I motor honey'd and covered with a plastic bag that still looks brand new.
Old Jan 13, 2006 | 12:43 PM
Z28SORR's Avatar
This is also a good time to grind off the sharp edges and excess flashing. Makes handling the block much much nicer.
Old Jan 20, 2006 | 01:49 AM
PontiacCowboy's Avatar
I usually pressure was the block and attack it with solvant and a wire brush then paint away. all my blocks i have done like this have been looking good for a long time.
Old Jan 25, 2006 | 08:08 AM
LameRandomName's Avatar
BTW, Brake Cleaner is an excellent way to do a final de-greasing before painting.
Or, if you can get it; Pentane. It's not illegal, just uncommon.
Be aware that if you do find a place that sells it, it's a "Flam-4". Gasoline is only a 3. In other words, no smoking, no source of ignition anywhere near you and good ventilation.
Sergio
Jan 27, 2016 04:27 PM
ModdedNerd
Dec 14, 2014 10:28 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
