Holley Street Avenger question(s)
Old Jun 18, 2003 | 09:15 AM
SLO SS K2's Avatar
770 CFM on a 383 w/200 cc runners 2.02/1.60 1 5/8 to 3" headers, true duels 2.5" no crossover. Air Gap RPM intake 6AL
From idle to WOT, shotters shoot, Revs goup then bang, total hesitation. Timing and elec are fine. Maybe the acc. punp, but I'm not sure. Float levels are fine, max mani pressure. If at higher RPM or Rs coming down. tire (grrr) spins. Any suggestions would be appreciated. Holley say Acc. pump may be the issue
Old Jun 19, 2003 | 10:04 PM
79_z28406sbc's Avatar
ok i have a 406 same set up allmost i had the same problem switch you front jet to the back and put like a set of 68 in the front so it should be like this 68 in the front and like 72s in the back and back the nut off on the accl pump a little and you mite have to switch advace springs in the disributor to a set of lighter one i did all that and it helped a **** loadthe springs helped a lot on mine it will burn them off in first gear at 30mph if i punch it and inialate them it i start from a stand still
RUENUF
May 25, 2016 08:10 PM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Queens94z28
Dec 20, 2014 09:11 PM
