Gear head Decode
Old Nov 1, 2007 | 08:49 PM
91gsixty's Avatar
Gear head Decode
Newbie to classic.
what does
350 Block Specs: Dome vol. -5cc
C/R: 58cc - 11.1:1; 64cc - 10.3:1; 70cc - 9.6:1; 76cc - 9.0:1 (add .1 for 4.060''). 1.560'' C/H, 5.7'' Rod, 3.480'' Stroke. 8/pkg.
Old Nov 1, 2007 | 09:21 PM
Stephen 87 IROC's Avatar
Orange
Old Nov 10, 2007 | 06:39 PM
Amy98Z's Avatar
It sounds like a description for a set of pistons. If you're asking what it means, they're describing the compression ration you'd have with different heads. The pistons are for a 350 Chevy with stock rods (5.7"), stock stroke (3.48"), and would give you 11.1 compression with 58cc (combustion chamber size) heads, 10.3 compression with 64cc heads, etc. etc. They also said you would get a little more compression (.1) if it was bored to 4.060" (stock was 4"). Hope that helps.
HectorM52
Jul 30, 2017 11:46 AM
njspder
Middle Atlantic
Jan 8, 2015 11:13 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
