Gangsta Lean
Gangsta Lean
I thought I saw this posted before, but I couldn't find it using the search. My car has, for a lack of better terms, a gangsta lean. If you look at my car from the back, the rear end kinda kicks an inch lower to the left than it does to the right. I checked the tire pressure and the pressure on both left tires was about 10 PSI off of where it should be, but I still have a slight lean after filling the tires. Think it could be suspension or could I possibly have twisted the car slightly? My 327 has some output, but I don't think it's enough to put any twist on the body. Any easy way to check without blowing a grand on new dampers and springs? The car does creak a bit when pulling into the driveway or going over a speedbump, so it probably is time for some new stuff
All 1st gens have this problem. Usually its attributed to bad springs, but sometimes they even lean a little when those have been replaced. If the springs are new, you can try replacing the shocks. Air shocks will allow you balance then out, however I'm not a huge fan of them so I'm willing to sacrifice a slight lean for an improvement in performance.
Yeah, my gearhead buddy also suggested air shocks, but this isn't a show car, it's my street hotrod
As long as everybody else has the lean I'm fine with a little ghetto style off the back end of my car. I just didn't want to have the only 1st gen cruising around with a little shimmy to the left, you know?
Air shocks have been around for a long time...you run a valve usually under the rear license plate or something and use a tire inflator to fill em up and jack the rear up/down/left/right usually for a performance improvement at the racetrack. Air bags are usually used by show cars/trucks who want to 'lay rail' by dropping all 4 corners to basically rest the car on the ground. The latter setup replaces springs, whereas the air shocks don't.
cmsmith
Sep 14, 2015 09:25 PM
Noct
Jul 14, 2015 01:18 AM
