which engine do i choose
Old Jul 19, 2004 | 07:50 PM
blueeyedsin's Avatar
i am rebuilding a 77 camaro type lt. the original motor is gone, currently has a 350 with more problems and missing parts then i can even handle. i want to drop in a new crate motor. im not sure exactly what size i want. i want power and horse power. i even want the option of side exhaust pipes. please help me with some info on this.
Old Jul 19, 2004 | 08:26 PM
406TA's Avatar
Re: which engine do i choose
It depends on what kind of power you want and how much $$ you want to spend.
Mild: http://www.sdpc2000.com/cart.asp?act...tart&catid=130
Medium: http://www.sdpc2000.com/cart.asp?act...id=120&pid=115
HOT: http://www.sdpc2000.com/cart.asp?act...120&pid=156334
Then you have your SICK motors...BBC!! Or build a nice 406sbc and kick @ss!!
BTW, don't go with sidepipes. Stick with 2.5" duals with good mufflers.
Check out nastyz28.com. Great site for 2nd gen. Camaros!!!
Old Jul 20, 2004 | 07:49 PM
rhamm1320's Avatar
Depends on your budget and planned usage. The 350 is going to be the cheapest and will give good power. You can install a 400 crank to make it a 383 (you will need to use the 400 rods or use a special piston and 350 rods). You can goto the 400 and get great torque, but it will run a little hotter than a 350 block. Finally, for more a race engine, you can goto a 377 (400 block and 350 crankshaft).
I have had all four in the past. IMO the 383 is the best bang for the buck for a street engine.
Old Jul 20, 2004 | 08:54 PM
from the sites you gave me, the 383 looks like a good deal. i like the power it puts out. do you know if there is any difference in the bolt patterns or mounts? why are the side pipes a bad idea?
Old Jul 21, 2004 | 11:28 AM
jg95z28's Avatar
FWIW, I'm in the process of putting that motor in one of my 67 coupes. It's for a daily driver.
Old Jul 21, 2004 | 08:29 PM
the 350 doesnt seem to be enough for me. i like the daily drive, but i also want to win a few of the races. the 383 is more in my price range but that zz502 would be grand. i just dont know if the mounts will match
Old Jul 27, 2004 | 01:49 AM
Ace_437's Avatar
They usually look like crap, unless you're driving a Viper, or the ZZ Top car.
Old Jul 27, 2004 | 01:51 PM
angel71rs's Avatar
A 383 or 400 will bolt right in place of a 350. Only specific parts different are the external balance flexplate & dampener that are needed with these engines. Unless you pop extra $$$ to have the rotating assemblies internally balanced. But motor mounts, tranny pattern, intake, headers, etc, are compatible off your 350.
Old Jul 27, 2004 | 11:05 PM
ws6transam's Avatar
Here's another way to go on the engine opptions: A 425 HP 383 from Dallas Export Sales/ It's less than $4K.
http://www.strokermotor.com/383425LB.htm
They also make a turn key version with everything from carb to oil pan for a little over $5K.
Old Aug 1, 2004 | 10:31 PM
homicdl's Avatar
i have a 79 camaro z28 with a rebuilt 383 stroker motor in it. roughly 425 horsepower. that i'm selling complete proable with the super comp headers that will fit right in your car. if interested let me know looking to get 3500.00 for it
DirtyDaveW
Dec 1, 2016 05:37 PM
meissen
Jun 1, 2015 07:59 AM
grabbem88
Feb 22, 2015 11:16 AM
Ken Cemo
Feb 13, 2015 08:37 AM
