decode my rear? is this a 8.5 10 bolt?
Old Sep 5, 2009 | 09:03 PM
User56898's Avatar
need some help decoding my rear end that's in my 67
the only things i could get off were the casting number on the driver side (1285542B) and some other number on pass (GM15)
please help
Old Sep 11, 2009 | 09:27 PM
tom2's Avatar
Just look at the rear cover. If it has one cover bolt at the very bottom, it's a ten bolt. If it has two bolts level across on the bottom it's a 12 bolt. I think the first gen 10 bolt rears were 8.2 inch ring gears. Most guys will find a Nova rear from the early 70s with the 8.5 gear.
Old Sep 12, 2009 | 09:51 AM
User56898's Avatar
thanks for the help
i know it is a 10 bolt just wanted to know if it is a 8.2 or 8.5
Old Sep 12, 2009 | 02:32 PM
angel71rs's Avatar
8.5 will have 2 triangle shaped lugs at bottom sides of casting, like this (post 7):
http://www.hotrodders.com/forum/rear...ing-82449.html
7.5 will have 2 pips in the same spot, but no way will you confuse a 7.5 for an 8.5.
Old Sep 14, 2009 | 08:23 AM
twozs's Avatar
Old Oct 13, 2009 | 11:24 AM
ssclone's Avatar
67 didnt have a 7.5. plus the 7.5 cover is different
8.2 and 8.5 uses same cover.
8.5 will have 2 ears on the bottom of the pumpkin at about 5 and 7 o'clock
8.2 will not have them. they have a half circle kind of deal missing from them.
8.2 parts will fit in an 8.5 housing but not vise versa.
8.2 had 9/16" ring gear bolts with reg thread pattern, 8.5 had 5/8" bolts with reverse pattern.
hope this helps
aaron
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
