Clunk from rear upon launch
Old Nov 3, 2004 | 06:16 PM
  #16
will69camaro's Avatar
Re: Clunk from rear upon launch
When my car had the 355 4speed in it i broke a motor mount and the engine rocked enough to make a LOUD knocking sound but it seemed more from the middle of the car (header hitting floor). Maybe check the rearsprings like has been mentioned, maybe they are week and either hitting the bumpers on the traction bars or spring wrap-up on launch.
William
I would like to check out some cars in the houston area sometime, maybe in the spring. I'm at A&M and my car should hopefully be operational by spring time (LT1/T56 swap).
Old Nov 9, 2004 | 10:33 PM
  #17
king1138's Avatar
I had this exact problem in my 1982 Z28 after my engine swap, with acceleration, the exhaust traveling through the piping rapidly increases in speed, causing a shift in the exhaust, if the piping is not fully mounted in place it will hit the floorpan between the catylitic conv if equiped, and the rear axle, are this is where the pipes are closest to the floorboards. check you exhaust.
blkWidow
Apr 21, 2015 01:56 PM
warmeck
Mar 22, 2015 06:43 PM
Fatdog2
Feb 12, 2015 12:24 PM
mark0006
Dec 25, 2014 09:50 PM
ModdedNerd
Dec 18, 2014 10:52 PM
