changing oil after storage...
Old Apr 16, 2004 | 07:10 AM
chevyman1969's Avatar
My engine has been sitting for almost 6 months without being turned over. I winterized the motor but it still has last years oil in it. it is going to be about 70-75 this weekend so should I just drain the oil without letting the engine warm up since oil has been draining off the internals of the engine to the oil pan for so long, and then prime the engine with new oil instead of last years that could posibly be contaminated with a little bit of fuel due to a float problem that happened on the last day at the track. Thanks very much for any imput. Im just tryin to do whats best for the engine.
Old Apr 16, 2004 | 03:25 PM
kacy's Avatar
definetly change the oil without starting the engine when you refill it the oil will relube it
Old Apr 17, 2004 | 02:47 AM
bowtie-70's Avatar
If winterizing included an oil change there is no need to change it now. If it didn't, I would go for a drive to get the engine up to full operating temp for awhile and change it hot. You need to mix up all the gunk in the engine before draining.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
captcorvette
Mar 7, 2015 12:37 PM
jasonduaine
Mar 7, 2015 09:44 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jul 4, 2005 05:00 PM
