Can someone explain Heads to me. I got 2 dumb questions
Old Jun 27, 2003 | 01:54 AM
  #16
teamsleep13's Avatar
Lookin at Chevy High Performances Database and I got three contenders for the 170 cc heads.... There is a 166cc, a 170cc, but it has 1.94/1.5 valves and a 171cc with a 71cc chamber.....
http://www.chevyhiperformance.com/te...98/index4.html
which one of those is it?
and is the 200cc one ur talking bout the last on on this page?
http://www.chevyhiperformance.com/te...98/index5.html
just wanna get it right.
Hunter
Old Jun 27, 2003 | 09:20 PM
  #17
zx1216's Avatar
Are the trick flow 23 Deg alum heads any good? Ithink they have a 195 cc intake runner. I also thaught i would run a 13.8 ish but runing at the track is A LOT different than on the street. Although i have 4.10 gears a 4-speed and a open diff. on 255 street tires. On the 14.4 run i pulled a 2.2 60'
Old Jun 30, 2003 | 12:01 AM
  #18
NeverGonnaRun's Avatar
The bigger heads will give you more peak HP and Torque, and if you want fastest 1/4 mile times then you should probably go with them. But remember on the street just cruising around it won't be as strong because it will make all its power up top. However, you can actually make less HP all around if your heads are too big for your cam. I'd say select a cam, talk to that manufacturer, and then get their opinions on heads, and go with one of the ones they recommend.
Also, that Edelbrock cam is old. I'd recommend going with a Crane or Comp Cams. Edelbrock is more of an intake and head specialist, Crane and Comp are specialists on cams, so you could probably get a cam with less duration and more lift that would make just as much, if not more, hp and still make more vacuum and not lope as much at idle. Basically, it would be more streetable.
oldschool
Feb 9, 2016 09:21 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
