camaro brake booster
Old Apr 28, 2004 | 06:15 AM
breakthelawinaz's Avatar
actually its not an F-bod but for my other car an X-bod, my 70 nova SS 396/375 4 speed. since those two cars are close to the came thing i thought id ask it here cause theres no X body forums around and im a member here. i have the factory power brakes and the master cylinder is no good and the booster is just too big it almost hits my valve covers i had to get to clear my roller rockers, and i was wondering if anyone swapped theirs for another vehicle model that is more compact? i beleive hot rod features a X or F body that had a mopar booster and master cylinder that was much more compact. thanks!
*eric*
Old Apr 28, 2004 | 01:23 PM
WTF? does anyone know?
*eric*
Old Apr 28, 2004 | 01:39 PM
angel71rs's Avatar
The booster used in this article might work for you:
http://www.classicperform.com/tech_a...rakes-tech.htm
Old Apr 28, 2004 | 02:22 PM
my only problem is i dont have disc rear brakes... would the master cylinder and brake booster off of my 86 Z parts car work? i just want something that bolts up im so tired of working on this car, i just want it to be done... its been apart for 8 years and is now a 650 horse beast and im not even going to try and fire it till its ready to roll... so someone help me....
*eric*
Old Apr 28, 2004 | 02:26 PM
XcYZ's Avatar
Buy one of these, booster problem solved.
http://www.hydroboost.com
Old Apr 28, 2004 | 02:31 PM
id i had the cash i would....
*eric*
Old Apr 29, 2004 | 11:45 AM
Red 69's Avatar
When I swapped the front drums on my car I pulled the brakes off a 70 nova. I have the same problem with the booster being too big. I had to use different valve covers because I didn't want to or have the $$$ to buy a new smaller booster to fit with my old valve covers (Edelbrock Aluminum).
I'll look into one of the ones suggested here now that I have a little stashed away.
Old Apr 30, 2004 | 06:15 AM
i CANT run smaller valve covers, my rockers barely clear the valve covers right now... i was thinking, i have a thirdgen parts car and would the booster off that work its alot smaler in diameter and i just want to know if i pound the studs out of the booster will the holes alogn for my X-body?
Old Apr 30, 2004 | 04:44 PM
kacy's Avatar
ive heard of people using newer camaro and s10 booster...the only problem with using a newer model m/c is that the use metric threads
Old Apr 30, 2004 | 07:14 PM
Red 69's Avatar
What kind of rockers are you using, my buddy has a 70 nova and he is using the same sized valve covers I am. We are both using the comp cams full roller rockers.
Is this a big block issue? Cause I am running a 400 sbc.
Old May 3, 2004 | 08:58 AM
its a big block thing, my friend has the same problem, so he took the roller rockers off and ran standard valve covers... ill figure it out... im going to try a few things and hopefully it will work..
*eric*
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ddr698
Jan 9, 2015 10:05 AM
Collector Car
Jan 5, 2015 10:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
