built 350?
Old Apr 13, 2008 | 10:36 AM
carzdac's Avatar
built 350?
Rebuilding a 40 over 350 speed pro hypereutectic w/coated skirt 3.5 dome, dart iron eagle platnum heads 230 intake runners 2.08"int/1.60exh, comp cams extreme energy with 520/540 lift and 282/290 duration with solid lifters. Witch rockers should be used 1.5 or 1.6 rollers, thinking 1.6 would be bettet. How much horse power do you think it will make with a performer intake and weber 750 carb? Its going in an 81 elcamino 4sp.
Old Jun 9, 2008 | 01:45 PM
redneckgames's Avatar
well those heads are alittle big for that combo, but we will look past that.
The intake does not match up with that. You need atleast a rpm air-gap, if not a victor jr or Weiand Team-G to complement those heads.
If you havent bought the rockers yet, put 1.6s on the intake, and 1.5s on the exhaust.
also what is the LSA of the cam?
Rittmeister
Aug 7, 2015 01:13 AM
Henson071
Aug 4, 2015 09:32 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
alphaauto
Jul 26, 2015 04:40 PM
1995Blackz28
Jul 20, 2015 09:34 AM
