Angle Plugs Vs. Straight
Old Mar 26, 2004 | 09:45 AM
silvertripper's Avatar
Which is better?
Also, will angle plugs work with headers?
Mark
Old Mar 26, 2004 | 01:06 PM
Zedzag's Avatar
Some say angled plugs are better due to the spark plug location but it all depends on the headers you are using. Do you have headers now? If so you have to check for angled plug compatability first.
Old Mar 26, 2004 | 02:26 PM
Im using headers from Mr.Gasket.... they are just plain 150.00 headers, the tube shape's is pretty common. The reason Im asking is that I dont have a set that I can compare to my headers as I'd be buying the heads from Summit. ???????
Old Mar 26, 2004 | 02:28 PM
Freak's Avatar
call summit or world products and ask them. they should be able to tell you if there will be a problem. also accel makes plugs that are shorter specificaly for angle plug applications
Old Mar 26, 2004 | 03:45 PM
Zedzag's Avatar
Do you happen to know the part# of the Mr.Gs? If so call them and ask or it may say on their site.
Old Mar 26, 2004 | 08:58 PM
Green95Z28's Avatar
A lot of the high-performance chevrolet stuff is angle plug, so I would think that they are better. There are a lot of other things that go into the decision on the heads though. If you call summit, they are very good at helping you decide. I think the angle plugs will work with your headers, but ask summit or the place you bought them to be sure.
Old Mar 28, 2004 | 11:04 PM
justens95z's Avatar
I say, buy the heads you want, and if you have some clearance issues with the plugs/wires, just buy some of the header plugs. It will take care of it. Or from looking at your list of rides, looks like you have the dinero, just buy some headers that will fit....big ones...
Old Mar 28, 2004 | 11:13 PM
jg95z28's Avatar
I just put Hooker Competition headers on one of my 67 Camaros with a 327 and straight plugs. #6 piston was next to impossible to get the plug in and then the boot on. I'm sure that plug wire isn't going to last long because it is definitely touching the header pipe.
The rest of the plugs were no problem.
Old Mar 29, 2004 | 12:56 AM
justens95z's Avatar
I've got a 71 Nova with a 355 and straight plugs in double hump heads, and never had a problem with my 8.8 Accel wires. Now my 95 Camaro LT1 car is another story.
Old Mar 29, 2004 | 08:09 AM
Well I have some sucky 882's on my 79 z with straight plugs and they fit fine under the tubes. But Im looking for some aftermarket heads and I'm finding alot of them with angel plugs. I know the plug's faces the intake valve's more, but I just wasnt sure if it was that much of a noticable difference in power and response between the angle and straight plug.
Old Mar 30, 2004 | 01:55 PM
SS69MAN's Avatar
Just look at your header arrangement. My biggest mistake on my car was not getting the angle plugs. Damn spark plug is right behind the header.
DirtyDaveW
Dec 1, 2016 05:37 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
