? about leaf springs for a 68 camaro
Old Apr 30, 2003 | 10:49 AM
chads68's Avatar
I purchased a 68 camaro about 4 weeks ago. The car leans to the drivers side. Should new coil and leaf springs fix this problem?
I have heard a few people with the same problem say it didn't fix there's. If not what would it be? Also, should i go back with mono-leaf or change to multi-leaf?
Thanks in advance,
Chad
Old Apr 30, 2003 | 11:38 AM
ahotrod79's Avatar
Chad, new leaf springs may fix your problem. My car was leaning to the passenger side and after I replaced the springs, my car did not lean anymore. But some people have replaced the springs and it still leaned which could be caused by worn out rubber body mounts or just a tweaked frame.
As far as mono or multi that is up to you. I had mutli leaf springs originally on my 68, but went with some parabolic monoleafs when I replaced them. I did this because I know the setup I have will allow me to put a lot of power to the ground at the drag strip.
Old Apr 30, 2003 | 12:33 PM
jy211's Avatar
mine leaned as well. I changed the rear leafs and that fixed the problem...
Old May 1, 2003 | 09:44 PM
chads68's Avatar
Anymore ideas or opinions?
Thanks,
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Dec 25, 2014 05:51 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
Dec 1, 2014 08:08 AM
siguy
Nov 27, 2014 10:07 AM
