79 305 Engine oil chioce
Old Jan 12, 2009 | 08:11 AM
79CamaroSparky1's Avatar
I just purchased a 79 Camaro with a 305 engine. For the looks of the car and engine it appears that the 55K on the odometer is ACURATE. I can't see how this car would have 155K on it based on the condition. My question is regarding an oil choice and oil filter choice for this engine. I plan on changing both at a 5K mileage interval. Thank you!
Old Jan 14, 2009 | 09:45 AM
Z28SORR's Avatar
If your going to change it every 5000m you may as well use the manufactures recommended non-synthetic oil. Which I think is 10W30, check your owner manual.
Old Jan 16, 2009 | 03:12 AM
jasonspd's Avatar
Fram PH30 or PH5 which is the same but is longer and holds a bit more oil and has a larger filter element. I run them in all my old cars. 10W30 in the summer, 10W40 in the fall or when it's cold. Just my $.02
Old Jan 16, 2009 | 09:34 AM
Z28SORR's Avatar
You've got that backwards. You should run the 10W30 in the winter and the 10W40 in the summer.
Old Jan 17, 2009 | 01:43 AM
jasonspd's Avatar
Yeah, you're right. I was tired and at work. My fault.
Old Apr 10, 2009 | 02:00 AM
Dragons77LT's Avatar
If I'm going cheap I use Valvoline 10w30 with a bottle of lucas and an AC Delco filter.
If I have the money I use Mobile1 15w50 and a Mobile1 filter.
Old May 22, 2009 | 11:34 PM
sifa123's Avatar
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Jul 4, 2005 05:00 PM
