76 firebird formula questions
I might be selling my v6 in favor of a 1976 firebird formula with a 400ci big block. It has an automatic trans. My question is how much horsepower and torque does this car produce? Are there any known problems that the car has? How reliable is it gonna be? I was looking online at a similiar year trans am with a 350 and the article said that it made 150 horsepower. I'm hoping this car will make much more power than that. Any help is appreciated.
Hate to say it,but your 3.4 makes almost as much power and is probably as quick in the 1/4 mile.The 400ci in 1976 put out a whopping 185hp.Here are the best specs I could find on a stock car:
Pontiac Firebird Trans Am 400
0-60 = 9.8 sec
1/4 = 16.8 sec
Hope this helped.
Kevin
0-60 = 9.8 sec
1/4 = 16.8 sec
Hope this helped.
Kevin
Originally posted by Rob94
thanks for the info, i guess i saw it had a 400 cubic inch motor and got a little excited, if its not significantly faster than my v6 i'm not interested.
175 horses is what's claimed for my '79 Z with a 350. The stock 400 should make more than that. Back in the day, Ponitac almost always pushed slightly more power than Chevy did with the use of an engine that Chevy wasn't making available to Camaro buyers.
It should have 185 horsepower. BUT it also has 310 Ft-lbs of torque.
Since it's a '76 it comes with a catalytic converter. If you were to do as said and swap the headers, depending on what state remove the cat, and run a dual exhaust. With a good intake. You should see low 14's, not 15's.
My '79 Z is faster than my V6 Camaro which runs a 14.9 to 15-flat, and although not stock, my Z has very little work done. And an open differential. It feels like a mid 14 second car as is (have not taken to the track yet)
So, you should easily be able to knock down a high 14.
Good luck.
Good luck.
Stock 3.42's.
I ran a set of long tube headers from Headman,
a 1405 series carb (600cfm),
a more aggressive cam profile (under .500's lift),
and a Trans-Go stage II shift kit.
The engine is also de-smogged (not by me)
haven't seen you around in a while, holler at me on AIM sometime Steve. What up???
The 400 is not a big block, by the way. That horsepower rating seems pretty close. My old '72 Buick Skylark with a 350 was factory rated at 195 hp. Of course I had to spend over $2000 souping it up to about 300 hp, only two spin it out and bending the rear-end.
Sold the whole car for $1000 a few months later. I miss that car.
'76 Trans Am= 3820 LBS. Power to weight ratio .0484
160HP vs 185HP = equal.
'94 V6 Auto = 3288 LBS. Power to weight ratio .0608
'76 Trans Am= 3820 LBS. Power to weight ratio .0811
200 Ft-lbs vs. 310 Ft-lbs = really not equal!!!
