700R4 in a 2nd gen
Old Jan 27, 2006 | 09:28 PM
cc89formula's Avatar
700R4 in a 2nd gen
Has anyone ever put a 700R4 or a 200R4 in a 2nd gen pontiac? Ive got a 78 TA with a pontiac 400 and turbo 350 that i want to make into a highway car. Im wondering if its possible and what would have to be done. I know the bolt pattern is different so is there someone that makes an adapter for it? would i need a different size drive shaft? thanks in advance
Old Jan 27, 2006 | 10:58 PM
IRONFIST's Avatar
Re: 700R4 in a 2nd gen
Yah, a 200R4 will bolt right in man, and they already have BOP bolt patterns. It's also the same length as your TH350 so the drive shaft is the same. The only problem is you'll have to move the cross member and redrill.
Old Jan 27, 2006 | 11:18 PM
PontiacCowboy's Avatar
op is right, pretty much GM is GM when it comes to trannys
Old Jan 28, 2006 | 12:33 PM
thanks for the info!
Old Jan 28, 2006 | 02:26 PM
anthony714's Avatar
yes,pretty much a bolt in job and since you have flexability in the crossmember you can move it easily.also your shifter???your stock one dont have a 4th gear position remember?i dont know too many options to fix that but i think bm makes the megashifter for a 2ndgen to work with the 4 speeds.
not sure though,im a 3rd gen guy.
also look around for a tranny,dont get a 200r4,they not any worse,but theres not too many parts for them.if you go with the 70,try to get an 88 and up if its hasnt been modifird yet.the newer trans have better upgrades for builds,save a few bucks.you can upgrade an older one but it will cost u more.
Old Jan 28, 2006 | 04:27 PM
the 78 is a 200 hp 2.56 rear end car, its not going to have much more power added to it, i want gas mileage out of it so im not worried about it being strong.
Old Jan 30, 2006 | 02:06 PM
Tru2Chevy's Avatar
There's actually a decent amount of parts available to build up strong 2004R's, they came stock in Grand Nationals and T-types
I buddy of mine is currently getting his 2004R built to handle 900hp and tossing it into his '76 Camaro. He figures that will be more than enough to withstand what he's gonna throw at it.
- Justin
Old Jan 30, 2006 | 02:29 PM
anthony714's Avatar
tru theres enough 200 parts to buld on but finding a guy to do it right is hard.most only know the 700..actually id prefer a 200.it has a a tad lower first gear(numerically) and a tad higher overdrive.so you get the best,wicked launches in first,the 700 can be kinda high for some cars ,and a lower overdrive kicking your higway rpms down that much more.and since the first gear is lower the drop to second isnt as much,keeping car in the power range more..
brothaslide
Jan 9, 2016 12:11 PM
NewsBot
Aug 3, 2015 02:40 PM
detroitmuscle
Jul 31, 2015 04:21 AM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
