68 12 bolt
Old Nov 24, 2003 | 06:22 PM
MTmace's Avatar
68 12 bolt
Did the 68 camaro come with a 12 bolt rear end?
If not which rear end will fit my 68 camaro?
MTmace
Old Nov 24, 2003 | 07:35 PM
jg95z28's Avatar
All Z/28's and some SS's came with a 12-bolt.
Old Nov 24, 2003 | 08:35 PM
angel71rs's Avatar
67-69 Camaro 12 bolt and 70 Nova 12 bolt are direct interchange, except for the multi/single leaf issue and non-staggered shock configuration on the 67's.
Old Nov 25, 2003 | 10:37 AM
jg95z28's Avatar
From CRG:
Q: What models received 12-bolt axles?
A: 12-bolt axles were installed on all SS-396s, all SS-350s (with possible exceptions in 1969 noted below), and all Z-28s. In addition, 12-bolt axles were installed on the following cars:
1967-8 L30/M20 cars from approximately Dec 1966 through the end of the 1968 model year.
All models with the 1969 factory 4-wheel disc brake JL8 option.
1969 cars with the LM1 engine. It appears that the 12 bolt was used with all 4-speed and automatic transmissions. Use on the manual 3-speed transmission cars is unknown.
1969 cars with the L65 engine (which replaced the LM1 engine) and 4 speed transmission. Data is erratic on this drivetrain combination, some cars have 10 bolts, some have 12 bolts. Please contact us if you have a car with this drivetrain.
Note: GM documentation indicates that 1969 SS-350s and LM1s with automatic transmissions may have received a 10-bolt rear axle. So far only SS-350 cars with powerglides have been observed with 10 bolt axles. Please contact us if you have a car with this drivetrain.
Furthermore, mid-year 67 models with 12-bolts received a passenger side traction bar or "radius rod" which was not used after moving to a "staggered" rear shock set-up in 1968.
1967 Camaro Radius Rod
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
