67 Camaro rear window resto
Old May 4, 2003 | 01:15 PM
William Barlow's Avatar
I am starting to restore my 67 Camaro and the only rust on the car is some in the floor pans and around the back window. I am going to replace the floor pans with new ones, but I can't find anyone that makes a repair section for the area around the back window. I have been told that somebody makes it, but I can't who it is or if someone really does. Any help, Please!! My only other option is to fab the section myself.
Old May 4, 2003 | 09:10 PM
anuarism's Avatar
If you are talking about the piece between the window and the trunk lid I think Year One has them.
Old May 5, 2003 | 12:49 AM
CHPshown67's Avatar
Classic also makes the piece between back windshield and trunk if that is what you are talking about, if you are talking about the window itself I went through a whole fabrication process with my window molding clips because of rust damage, I can give you some ideas.
Old May 5, 2003 | 11:04 AM
Yes, I am talking about the area all the way around the back window. The tabs for the molding clips are still in place, but there is some rust above and below the tabs. Thank you for any help.
Old May 5, 2003 | 02:24 PM
CHPshown67's Avatar
You are actually lucky, my car had a few clips completely rusted off. The body shop i took it to bought replacement clip studs and new clips and just fabricated new metal into the slots, if you are only missing a small amount of metal any good body shop should be able to fabricate it. I have also heard of guys cuting the whole back windshield section out of a non-rusted car, but your rust isnt that bad, and finding a 67 with no rust at a junkyard isnt likely. I would talk to body shops and find out about fabricating new metal. I had one shop tell me they would fill it in with Bondo, and i laughed at them and walked out. Make sure its quality work, this is one thing not to go cheap on.
Also look for rust in the dash at the bottom of the front windshield, also a common place for rust, and better to fix it now.
Old Oct 29, 2012 | 06:16 AM
MuscleCarMan's Avatar
Re: 67 Camaro rear window resto
Found your 67 Camaro back window repair panels here. 67-69 Camaro / Firebird Back Window Channel Rust Repair Panels http://amp-my-ride.com/Window_Repair_Panels.html
Your Welcome.
Old Oct 30, 2012 | 03:18 AM
Jerry502's Avatar
Old Nov 13, 2012 | 09:55 PM
97z28k&N's Avatar
this thread is from 2003...
Posted from Camaroz28.com App for Android
rockync7
Jan 1, 2015 05:10 AM
Jazsun
Dec 29, 2014 12:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
Snoman73
Nov 17, 2014 07:22 PM
