6 Speed Tranny Swap
Well, I guess you have a T56?!!!! Depending on the version you have (LT1, LS1, etc.) there are a few other kits. Auto Touring Specialties makes the nicest I've seen for both LT1 and LS1 models. I've also used a Weir Products kit that comes with it's own bellhousing to use a standard clutch with the LT1 style trans. Both kits have the crossmember, brackets, hydraulic pieces and lines, etc. for a complete install.
Jody
Jody
I am working on getting the tranny as I write this...I need all the help so I don't buy the wrong stuff....
thanks for the info....
This will be added to a 396 I am dropping in the car.....
I have all the needed compnents to make your swap a bolt in. email me off the board for more details, or see http://www.pro-touring.com/t56
Tyler
Tyler
