400 Small Block
Old Feb 3, 2003 | 09:48 PM
FormulaLT4's Avatar
400 Small Block
I have a 1970 400 small block to cure all the oil leaks I am replacing all the seals on the lower end and as an added safety thing I want to replace the pan w/ a new one. Now the dealer hasn't a clue on something that old. What later pan will work?
My dipstick is on the left.
TIA
Old Feb 4, 2003 | 12:17 PM
97z28/m6's Avatar
go somewhere else (like a speed shop).
Old Feb 4, 2003 | 06:19 PM
1981zzz's Avatar
Im not one hundred percent but a 350 oil pan should fit most other parts are inner changable
Old Feb 4, 2003 | 09:03 PM
Damon's Avatar
I think a 350 pan will fit, although in all the years I don't ever think I actually tried it. Dipsticks that go through the block are likewise not a problem from pan to pan. Even pans that didn't have a through-block dipstick have the little cut-outs for them down by the pan rail.
Old Feb 5, 2003 | 03:49 AM
ahotrod79's Avatar
Believe it or not, not all 350 pans will fit a 400. You need to make sure the pan specifies that it is for a 400. I got one that said sbc 350 and the sales guy thought the same thing i did and said it should fit, but whn I went to put it on the holes did not line up. So I took it back and we found one in his catalog that specified sbc 350 and 400. I got that one from them and it fit fine.
By the way I have two oil pans for sale (both fit a 400) if you are still looking for one. I have a stock type pan and a milidon low profile 7qt pan.
Old Feb 5, 2003 | 08:25 PM
FormulaLT4's Avatar
Thanks for all the help guy's. Jason Cromer did a lot of research for me and is getting me a 400ci truck pan. It seems the car ones are no longer available from GM
Old Feb 6, 2003 | 02:07 PM
BIGBADBOWTIE's Avatar
If you cant find a pan I may have one that will work. I have 400 sbc pan that came out of a 76 Burban. Its not in the greatest shape(its been in minnesota). I can take a few pictures if your interested. Ill let you have it for 15 bucks plus actual shipping cost.
Let me know if your interested.
Old Feb 6, 2003 | 05:36 PM
FormulaLT4's Avatar
Sorry, but I want a new pan. This engine leaks oil from every possible place that it can. So I am resealing everything from top to bottom and using all new stuff, pan, valve covers, front cover, front seal and the rear main.
But I appreciate the offer, Thanks
geinsteder
May 6, 2015 06:02 AM
dpw21562
Apr 16, 2015 09:41 AM
ad356
Apr 11, 2015 08:49 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
