350 chevy motor info
Old Nov 12, 2011 | 04:21 PM
undecidedfbody's Avatar
I had just acquired a sbc350 and had some questions
It appears that the deck was milled so I can't get any numbers
Some one told me to look on a machine pad for numbers. I can't find a machine pad anywhere. Any help with that
Was told it was a 383 stroker
It's a 3970010 casting block and has 010 and 38 stamped everywhere, what is this for?
I looked up the Number behind pass head j 16 8 and it was made October 16 1968 am I correct?
I ripped apart the block it had I guess iron heads?
They have a 7959 on them what is this ?
I'm unsure about that,is there any way to tell?
It has trw or speed pro L2256 .030 pistons
Gm stamped rods
Gm stamped crank with the # 3932442
it has Manley guide plates,Manley rods and really big 1.5 roller rockers stamped with USA on them
I can't find any more numbers
I removed lifters and they seem to be a solid roller.
it is a four bolt main block. is there a way to tell if it was splayed or if it was a sock 4 bolt
I will be taking wp and timing cover off within the week To check cam
Just wondering if someone can give me some info on this
Thanks guys for the help
Old Nov 14, 2011 | 08:55 AM
jcl69cam's Avatar
Re: 350 chevy motor info
Sounds like a 355 w/the 30 over pistons. If the main bolts go into the block straight, then its a regular 4 bolt block. Splayed mains the bolt goes in on an angle. Could be a 383, depends on the stoke of the crank, and rod length.
Old Nov 14, 2011 | 10:26 PM
Ok here is the question how do I check rod length and crank stroke. I guess it is a stock four bolt cause the bolts are straight in.
Old Nov 19, 2011 | 07:47 AM
sweetsoul's Avatar
the crank ending in 442 means it is a cast crank 3.48 stroke.
Old Nov 21, 2011 | 01:00 PM
So I'm assuming it's a 350 crank so it's a 355
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Chris Anderson
Jan 27, 2015 08:30 AM
NewsBot
Dec 28, 2014 06:20 PM
formula79
18
Jul 1, 2002 02:39 PM
