350 build questions
Old Sep 15, 2009 | 11:02 AM
FirebirdFormula502's Avatar
350 build questions
I'm building my first small block and need some help on what to do. I want a good reliable motor that will run on pump gas. This car is a weekend driver that may see the track maybe twice a year. I'm looking to make around 400 horsepower (give or take a few) without having to go the 383 route. I may go with nitrous later down the road, but not any time soon. What combo will I need to accomplish this?
This motor will be going into a 76 vette with a 350t trans
Old Sep 16, 2009 | 07:33 AM
redneckgames's Avatar
400 hp is easy with a 350.
How much money do you want to spend?
Budget: Hyper flat top pistons, vortec heads (worked for more lift), edelbrock RPM-air gap, 600 holley, with a flat tappet cam to match
More money: Forged flat top pistons (floating not pressed, for rpms), Dart Pro1 200Ps, edelbrock rpm-air gap, 750 holley, roller cam to match combo, comp pro magnum ultra rockers
Old Sep 22, 2009 | 04:04 AM
SupplySgt.'s Avatar
+1 on vortec heads. that will do wonders for your power. When I have more of a budget I may go that route on my 79 myself. The SBC does have potential if you know how to wake it up.
Old Sep 22, 2009 | 06:43 PM
AutoRoc's Avatar
Ram Jet 350 crate engine might be an option. Do some measuring and see if it'll fit under the hood. It should.
Is this a roller block or the original 1976 engine being rebuilt?
Old Oct 8, 2009 | 01:10 AM
MachinistOne's Avatar
400+ with 91 octane and excellent manners is not hard for a 355.
We just did one this week for a '67 Camaro
Dart 200cc Platinums + just a little extra time rolling the SSR
KB hyper pistons @ 9.5:1
Scat I beam rods(only because his were junk)
Victor Jr. Intake(already owned - RPM Air Gap would work just as well)
Comp XE Hydraulic Roller cam
650 Holley(non-HP series)
Made 375 at the tires at only 6K RPM, that's 430 at the crank - just a real basic cruising motor that has an absolutely flat torque curve. If you want to make more you can switch to aluminum heads and bump the compression.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Jrlt1
Jan 3, 2015 07:38 PM
Lederman1976
Nov 30, 2014 05:21 AM
squirrels
Jul 13, 2002 01:58 AM
