327 vs 350
Old Jan 30, 2007 | 01:09 AM
  #16
new2chev's Avatar
oh and im not downing 350s because they are a good all around engine.
Old Jan 30, 2007 | 11:40 AM
  #17
Z28SORR's Avatar
Originally Posted by new2chev
wasnt the corvette 327s four bolt mains? i think the 327 is a better engine. but then again from what i hear the 302 would kick a 327s *** and 350 w/out a prob. no replacement for displacement huh, i think i would have to disagree for the most part with small blocks. a 377 will run better than a 383 small block. im talking about non 400 based small blocks.
Well you can think what ever you want. But your still wrong!!!
Old Jan 30, 2007 | 03:27 PM
  #18
ratchetmaster's Avatar
I have two corvette 327s . . . 2 bolt mains. NO 327 4 bolt was ever made no matter the horsepower rating.
327s were and are still a very popular engine . . . they had excellent power throughout the rpm range . . . a very good engine. But of coarse there is no replacement for displacement!!! Rats rule!!
L8R
RAT
Old Jan 31, 2007 | 09:04 AM
  #19
DJ_951's Avatar
i guess we should be using 302's instead of 383's then, huh? a 302 has a FAR better stroke to con rod ratio.
The 302 was a leagendary Trans-Am racing engine.
I think half the reason way 327's have a magical name is none were made after emisions. Means most 327's are atleast 250hp.
Old Jan 31, 2007 | 01:03 PM
  #20
67 and 68 camaros, etc. with small blocks that had a standard transmission all came with an air pump (smog pump) on them. I have a 68 elcamino with a 327 with standard trans and the air pump. I also have a 68 camaro 327 standard trans with the air pump system.
Old Feb 1, 2007 | 11:34 AM
  #21
new2chev's Avatar
i would think corvettes would have 327s with four bolt mains. well i never said i was right. oh and im talking factory stock engines as far as 302s and 327s , and 350s. just to let you know. its like the 340 mopar is better than the 360s. but thanks for letting me know there wasnt a 4 bolt main 327.
Old Feb 1, 2007 | 12:23 PM
  #22
FYI
the 302 z28 engines also had the smog pump on them from the factory.
Old Feb 2, 2007 | 07:53 PM
  #23
RAT454's Avatar
Debating the best small block has been the subject of a decade or so worth of bench racing arguments and will probably always re-surface with no clear right answer. The key is determining the intended use, then arriving at a combination of components to meet your use…Mostly it boils down to just how much effort, money and time one is willing to devote to it.
Old Feb 5, 2007 | 06:36 PM
  #24
jg95z28's Avatar
Only 67's with std trans sold in California got the air pump. in 1968 the air pump became std. everywhere with the std trans.
Old Feb 7, 2007 | 06:14 PM
  #25
Yes, thanks for clarifying . . . 67 cal only standard trans cars. All 68 standard trans with pump. I am from california so I wasn't sure if they were also outside of cal or not. Saw the pump on my friends 67 camaro in 1977.
HAWG
Sep 25, 2015 11:41 AM
MDZ28
Sep 7, 2015 09:16 PM
Rittmeister
Aug 7, 2015 01:13 AM
Henson071
Aug 4, 2015 09:32 AM
