1987 SBC cam question
Old Jan 10, 2008 | 06:13 PM
HottestZ28's Avatar
My father in law is helping fund and give engine/trans to convert 87 2.8 to 350 camaro
The motor is 70 sbc, balanced and rebuilt .30 over, not sure of compression. Stock untouched heads, weiand single plane intake, holley 750 vaccum sec. TH350 with 3.42 stock 10 bolt rear
now the question what stall converter should I use with a Crane cam HMV278-2
duration at .050 222 int 234 ex
lift 467 292
what ballpark est. of hp/tq? looking to get a low 13 sec 1/4 for my wife
Old Jan 17, 2008 | 10:07 PM
byrons1502's Avatar
i would use the 2500 rpm converter because the torque might be low and should stall around 2200 rpm. you should look for a stall speed lower than the rpm the motor will travel at highway speed. if the converter is slipping and never fully locked it will overheat and burn the trans up. i would put a serious trans cooler.
if the compression is low and the heads are 1.84 valve you might consider a smaller camshaft and dual plane intake like performer rpm.
a 9.1 motor with 1.94 heads and your parts should see around 280-300 hp and 350-370ft lbs. the heads are a big weak piont for older gms. if the heads need done i would junk them and get a set of vortecs and expect 330-350hp
current combo should get low 14's, with good tuning possibly 13's but not likely
Old Jan 18, 2008 | 02:20 PM
Rice Killer87's Avatar
^^^^ Absolutely.
Check the head casting #'s at www.mortec.com . If they arent up to par performance wise stick them on Ebay and buy a set of hopped up Vortec heads.
Ditch that single plane intake as well...again,Ebay is your friend if you need the money...if not just stick it on a shelf.
Finding out the compression is a real decision helper as far as camshaft choices go also.
Old Feb 21, 2008 | 03:50 PM
byrons1502's Avatar
alabama cylinderhead is selling a vortec head that also has an older bolt pattern that would make that motor really wake up.
marineengineer
Feb 9, 2015 03:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
Lederman1976
Nov 30, 2014 05:21 AM
