1971 gasket thickness
Old Apr 19, 2005 | 08:42 PM
Max 93's Avatar
anyone know what the thickness of a stock head gasket is on a 1971, 2bbl, 9.0 to 1 ,350 out of a Monte Carlo if that makes a differance.
Old Apr 20, 2005 | 07:10 PM
markinkc69z's Avatar
Re: 1971 gasket thickness
.018" I think. Steel shim for sure. If it helps the MrGasket steel shims should be a nearly exact replacement. I had to take the head off my stock '72 350 2bbl Monte and that's what I used.
Old Apr 20, 2005 | 07:48 PM
Max 93's Avatar
thanks, I wasn't sure if they used a shim or something thicker
Old Apr 21, 2005 | 07:27 PM
rskrause's Avatar
Moderator
Sheeit, that is damn obscure question!
Rich
Old Apr 21, 2005 | 08:05 PM
Stephen 87 IROC's Avatar
If it's a steel shim like most production head gaskets were, I'd also say .018".
Old Apr 21, 2005 | 09:03 PM
Rich
LOL! you crack me up!
Old Apr 21, 2005 | 10:02 PM
Max 93's Avatar
Rich
Then how about this one.... The stock 350 with .018 head gasket and 76cc heads has 8.5 to 1 compression. If I switch to 67cc heads using the same type of head gasket, what is the new compression?
Old Apr 21, 2005 | 10:57 PM
rskrause's Avatar
Moderator
Easy one. It will go up to ~9.4:1
(76+15/67+15)*8.5=~9.4
Rich
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
