1967 camaro sub frame help
Old Oct 26, 2002 | 01:25 AM
vicki-ron's Avatar
i would like to know what years nova sub frame will fit on a 67' camaro ?
thanx
vicki&ron
Old Oct 26, 2002 | 11:26 AM
camcojb's Avatar
Is there something wrong with your current subframe? You don't need to swap subframes to get disc brakes.
To answer your question, the Nova subframes from 68-? (not sure when) do bolt in, not sure about a four door unit. Should be the same.
Jody
Old Oct 26, 2002 | 08:17 PM
Zoomin's Avatar
I think FatMan makes a subframe that is narrower to allow fatter tires and also has tubular control arms.
Old Oct 28, 2002 | 11:12 AM
68SuperRam's Avatar
You could also check our Martz Chasis - for custom front subframes.
Old Oct 28, 2002 | 12:30 PM
5SPDCHK's Avatar
68 and newer.
Old Oct 28, 2002 | 02:47 PM
texlurch's Avatar
Re: 1967 camaro sub frame help
thanx
vicki&ron
68-74 Nova, Astre, Apollo... or 67-69 camaro or firebird will interchange
There are quite a few aftermarket builders you have bolt in front frames that use late model or mustang suspension components
Old Oct 28, 2002 | 03:20 PM
Mister HP's Avatar
Nova subframes
'68-'72 Nova used the same subframe that '67-'69 camaro used. nova changed body slightly in '73-'74 ,but subframe should be the same. '75 - up Nova is different, but I'm not sure how much.
Old Oct 28, 2002 | 03:55 PM
68SuperRam's Avatar
I am actually looking to get rid my subframe - I had it sandblasted and powder coated black - it is in very good shape. In addition, I also have the upper and lower control arms (sandblasted and powdercoated) with new ball joints and poly-urtheane bushings pressed on - never used. Let me know if you are interested.
Old Nov 3, 2002 | 06:18 PM
scooters97ss's Avatar
I'm just kicking tires, but would you mind emailing me with a price when you get a minute?? Thanks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
CARiD
Jan 14, 2015 04:00 AM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
