98 Trans Am, black, WS6 hood, T-rex cam, 9" rear, etc
Old Mar 24, 2006 | 12:15 PM
BuckeyeROC's Avatar
It kills me to do this, but a business op calls and I need the cash.
1998 Trans Am, black exterior and grey interior, fiberglass WS6 (ram-air) hood, Torq Thrust II 17x9 and 17x11 rims, T-tops, leather, power everything, ~48k miles.
Pics:
http://community.webshots.com/album/548872828cZzqwH
Mods include:
Engine:
-Thunder Racing T-Rex cam (243/249 @ .050, .608"/.613" lift, 110 LSA)
-Patriot Gold dual spring kit
-Thunder Racing heat treated chrome-moly pushrods
-Rollmaster heat treated adjustable double roller timing set
-Stealth airlid w/ K&N filter
-Thunder Racing billet MAF ends, black
-Jantzer ported and black powdercoated throttle body
-LS6 intake manifold
-March underdrive pulley
-ARP Pro Series rod bolts
-Ported LS6 oil pump
-Prothane poly motor mounts
Exhaust:
-Edelbrock Victor Series drag headers: 1 3/4" to 1 7/8" stepped long tubes with merge collectors and off-road y-pipe
-Hooker cat-back
Tranny:
-Textralia clutch kit
-McLeod SFI 6.1 bellhousing
-Pro 5.0 shifter with Lou's Short Stick
-MBA billet shift ****, black with Trans Am logo
-Energy Suspension poly mount
Rearend:
-Driveline Solutions Ford 9" - 4.56's, Detroit TrueTrac, 31 spline axles, Strange SS case, Daytona pinion support, 1350 yoke, solid pinion spacer. 1/2" x 3" screw-in wheels studs
-Denny's Nitrous driveshaft (good to 2000 HP)
Suspension:
-Spohn Adjustable Tq Arm w/ front driveshaft loop and spherical rod end
-Spohn LCA's
-Spohn LCA brackets
-"BMR-style" Subframe connectors
Exterior:
-Fiberglass WS6 hood ($1300 parts and labor)
-17x9 and 17x11 Torq Thrust II's
Free Mods:
-!CAGS
-!EGR
-!A.I.R.
-! A/C (have all parts to put back on)
-Throttle body coolant bypass
-NGK Iridium plugs
-Taylor Thundervolt 10.4mm wires
Misc.:
-HP Tuners software
All it needs is a tune (I have $500 HP Tuners software that comes free with the car). This combo should net naturally aspirated low 11's @ ~120 mph in the 1/4 with traction, in a pretty much full weight STREET car. I was going to add a 150 shot on top of this, if you do, for another $600 or so, you can run ~mid 10's @ 128-130 mph.
I am asking $16,000 obo for this car, mainly because the following parts are BRAND NEW:
Textralia clutch kit ($1000)
McLeod bellhousing (~$400)
Denny's Nitrous driveshaft ($405)
Ford 9" rearend (~$2300)
Spohn Tq Arm ($450)
That's $4500 in BRAND NEW parts.
The majority of the other mods have only seen about 200 miles. This is an unmolested, uncut STREET car first and foremost. All the car will need is a tune and you're ready to go after low 11's.
email me at Mattlavrar@sbcglobal.net if interested, thanks.
Old Mar 31, 2006 | 05:55 PM
BuckeyeROC's Avatar
Re: 98 Trans Am, black, WS6 hood, T-rex cam, 9" rear, etc
bump
Old Mar 31, 2006 | 08:24 PM
stepuptata's Avatar
were are you in ohio? man, thats a huge cam.
Old Apr 3, 2006 | 05:31 PM
BuckeyeROC's Avatar
Around Toledo
Old Apr 6, 2006 | 08:35 PM
BuckeyeROC's Avatar
Old Apr 6, 2006 | 08:40 PM
TransAm396's Avatar
im trying to sell my car..once i do..i might be interested in taking a look at it. hows it drive?
Old Apr 6, 2006 | 10:41 PM
BuckeyeROC's Avatar
Drives/cruises great. Needs tuned for top end (5k rpm +) performance though.
Old Apr 7, 2006 | 02:18 PM
TransAm396's Avatar
is it on the stock tune?
Old Apr 7, 2006 | 05:19 PM
BuckeyeROC's Avatar
Not anymore. I downloaded a T-Rex tune from another HPTuner's guy. It still needs some work w/ a wideband, but it's definitely drivable.
Old Apr 8, 2006 | 03:28 AM
30thTA0525's Avatar
sorry this is an off the wall question but what size EXACTLY are you TT2s im looking too get those exact wheels and id like too know the backspacing and all that.. your car is killer TTT for you
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Jan 13, 2015 09:52 PM
Dec 17, 2014 11:00 AM
