1994 Chevrolet Camaro Z-28 ProCharger Supercharged - Professionally Built Engine +
Old Dec 17, 2024 | 04:37 PM
RUENUF's Avatar
This Single-Owner ProCharger Supercharged 1994 Camaro Z-28 (with numerous other engine, suspension modifications, etc.) has been professionally modified in a stage based fashion over time. Since originally purchased, it has always been both a great street and drag strip driver!
Listed below is a subset of many of the Professionally Performed Modifications:
ENGINE
ProCharger D1-SC Supercharger (6.5 PSI)
L.G. Motorsports G2 LT1 52 mm CNC ported/polished Throttle Body (780 cfm)
L.G. Motorsports G2 LT1 High-Flow Air Foil
L.G. Motorsports G2 LT1 Ported/polished intake manifold (matched to headwork)
L.G. Motorsports G2 LT1 Big Valve Racing Cylinder Heads (ported/polished)
Multiple angle flowbench developed valve job - hand blended to port work
2.00” and 1.56” Ferrea chrome stem stainless steel valves (one piece)
K-Line Bronze bullet guide liners
Competition Cams Chromoly retainers
Competition Cams 10 degree locks
Teflon valve guide seals
Hardened spring locators
A.R.P. screw in studs
Stepped guide plates
cc’d combustion chambers
Surfaced to 10:1compression
Flow tested on computer assisted Superflow 600 (approx. 270 cfm)
L.G. Motorsports G2 Superwires
L.G. Motorsports G2 Mass Airflow Sensor
L.G. Motorsports G2 LT1 Adjustable Fuel Pressure Regulator
L.G. Motorsports G2 LT1 Custom Grind Camshaft (.512/.512 lift int/exh 220/230 duration 112 lobe sep)
Competition Cams Pro Magnum 1.6 Roller Rockers
Fel-Pro LT1 Blue Head Gaskets
Champion Custom Spark Plugs (gapped at .0035; one temp range colder)
Hypertech Power Programmer Plus
Hypertech 160 Degree LT1 Thermostat
ACCEL LT1 Super Coil
ACCEL 300+ Digital Ignition System
SLP Jet-Hot Coated Headers & Y-Pipe
Borla LT1 Cat-Back Exhaust system
TRANSMISSION
Genuine GM 3:73 Gears
L.G. Motorsports G2 LT1 High Stall Torque Converter
Trans-Go Shift Kit
TIRES/RIMS
BF Goodrich 275/45/17 Front 315/35/17 Rear
ACT Aluminum/Titanium 17X9 & 17X11 Rims
DRESS UP
L.G. Motorsports G2-ZR28 Hood/Trunk Striping kit/Decals
L.G. Motorsports G2 Throttle Body Plate
L.G. Motorsports G2 White Guage Faces
L.G. Motorsports G2 Billet Valve Cover Breather
L.G. Motorsports G2 Aluminum Pedal Covers
L.G. Motorsports G2 Aluminum Door Sills
Auto Meter Monster Tach
Auto Meter Boost Guage mounted in A-Pillar Post Guage Pod
Braided Hoses
Painted Valve Covers (Red)
RK Sport Tailblazers Blackout Brake-Light Covers
SUSPENSION
L.G. Motorsports G2 LT1 Engine Bay Brace
L.G. Motorsports G2 Sub-frame Connectors
L.G. Motorsports G2 X-Brace
MISC. SPECS
Dynoed at 450+ HP at the rear wheels
In full transparency, this car just needs a couple small items to be fully ready. It's in need of an Opti-Spark or fuel pump, a red top Optima Battery, a repair to the lower linkage at the steering column joint, and potentially a paint job to the new owner’s preference. This car has been professionally built through its various stages and similarly built for Performance and Reliability. The interior is in great shape. The paint as indicated above is original, but as-expected time-degraded shape. My intent was to get it repainted sometime, however I never got around to it.
$11,500 - No trades please, and Cash Only. Serious buyers only. Please feel free to contact me with any questions
Also listed on Facebook Marketplace with pictures... https://www.facebook.com/marketplace/item/2449978048710658
Thanks,
Paul
Zdaddy
Jul 15, 2010 08:29 AM
Lt1Diablo
Jul 28, 2005 09:49 PM
Lt1Diablo
Middle Atlantic
Jul 18, 2005 06:52 AM
Iroc627
Mar 1, 2005 01:28 PM
