Yellow top under hood
can it be done? does anyone have any pictures??? cause a friend of mine swears it has to be trunk mounted but i could have sworn ive seen tons of pics of it done here.
Re: Yellow top under hood
Re: Re: Yellow top under hood
Originally posted by megabass
Haven't seen you around in awhile. But your friend is wrong. You can in fact put a Yellow top under the hood as a starting batter. That's where mine is
Originally posted by 97BBlackZ
im still trying to figure out what your talking about
Anthony, The only problem I had was that the black plastic hold-down piece wouldn't go back in place with the bolt. So I just used a large washer with the bolt instead. I've heard that the plastic piece can be modified to work. But I just tossed it aside and used the washer.
I also don't have any clearance issues on top either. I've heard stories of the hood hitting the top of the battery. Mine clears fine and I have top posts.
if i knew i would tell you... what is a yellow top? under the hood?
Why is that?
Why is that?
