Wiring front fill speakers... stupid question
Old May 19, 2004 | 09:04 PM
TopleSS 01's Avatar
I know this is probably basic, but. I am going to install my Focal 165 K2P's this weekend. I will be placing the tweeters in the A Pillars. I found the FAQ on how to remove the door panels any other tips?
Where to run the wires to the trunk
Easiest way to remove the front kick panel
Easiest way to remove A pillar
Any other tips? ... ...
I have a 2001 SS Vert & will be running 14 Ga 4 conductor Monster Cable CiPro Xln.
Tks.
T
Old May 20, 2004 | 08:12 AM
LS1 RULZ's Avatar
Re: Wiring front fill speakers... stupid question
Speaker wires go under the door sills, under the carpet, under the rear seats and into the trunk area. RCAs can be run down the middle of the car. The power cable can be run under the door sills with the speaker wires.
Remove the door sills and then remove the kicks.
Never done this myself but they should pull out easy enough. I believe they use plastic pins stuck into holes in the A pillar to attach.
Old May 20, 2004 | 07:59 PM
TopleSS 01's Avatar
Thanks!
i would not have known to run ther RCA's down the center.
T
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
