WIRES?/INSTALL questions
Old Jul 7, 2003 | 04:53 PM
  #16
DelSoto's Avatar
Too much power does *NOT* kill subs.....on the other hand, too little will. You just need to watch your subs excursion to make sure they don't move too far "in&out". I have 1200 watts feeding two JL 10s that are rated at (I think) 300 watts/ea. I have had these subs for 5 years and they still kick butt. I am running a sealed enclosure too. I think you will need to be a little more careful if you use a ported enclosure. I don't remember if you mentioned that or not.
Old Jul 7, 2003 | 05:47 PM
  #17
HurstWS6speed's Avatar
Originally posted by NineSevenWS6
Chances are that 801 is 800wrms @ 12.5, you give that thing 13.8+v and its pushing a lot more power. MTX is very conservative like that.
There have been pleanty of 1000d's that have giuve 2-3-400 wrms more than rated.
whats a 1000d im not up on my audio stuff dunno it all
Old Jul 7, 2003 | 11:05 PM
  #18
NineSevenWS6's Avatar
1000d = MTX 1000w class d amp
did your amp come with a birth sheet?
Old Jul 8, 2003 | 10:18 AM
  #19
i am ordering it tomorrow or friday, when my check is cashed
Old Jul 9, 2003 | 09:29 AM
  #20
i dont know much about audio as you all can tell but running 12.5v and 13.8+ whats the difference other then one uses more power and produces more.....what will it affect like will it drain the battery more or what
also can someone list all the ways of hooking up the subs like parallel and series and etc
and im just tryin to get this confirmed with someone else about my single coil 4ohm subs, if i twistand run both neg together and both pos. and run
Old Jul 9, 2003 | 11:16 AM
  #21
also, if i posted this earlier somewhere else i dont think i got a reply is there a sub that can take alot of rms power and not need a box made of something special to be stonger?
Old Jul 9, 2003 | 12:32 PM
  #22
DelSoto's Avatar
5/8 MDF should be strong enough to hadle anything those subs can dish out. If you want to read up on different configurations, series, paralell, etc.... I highly suggest a little effort on your part and a nice search engine like google. I'm not trying to be a ***** but there is just more that you can do on your own. If you run into a special problem or need good advice or want the opinions of some guys that have 'been there, done that' ya you can ask em here and they will be happy to answer. I have already answered your series paralell question at least once. Go look it up, I think you'll be happier with what you find anyways with pictures and diagrams. good luck!!
Old Jul 9, 2003 | 12:36 PM
  #23
Talking
thanks
Old Jul 9, 2003 | 12:41 PM
  #24
my problem with that though is i dont know what to type in to search how to hook it up in parallel
Old Jul 9, 2003 | 08:06 PM
  #25
foshizl's Avatar
i wouldnt hook it up in parallel, plus MTX Class D amps are wierd because of the conenctions on them, most class D amps just have 1 set of + / - connections for subs, the MTX class D amps have 2 sets of + / - connections so if your running 2 subs, you can just run a wire from each terminal on the speakers to each terminal on the amp, youd be running 2 ohms, i dunno if thats what you would want, but those subs should be able to handle it, like someone above said subs blow more often because they have too little power, then too much....
(i know alot about mtx stuff so if i didnt answer your question) ill check back.
Old Jul 9, 2003 | 10:15 PM
  #26
DelSoto's Avatar
Thanks for the backup foshizl. I didn't want to come right out and tell him not to do it although I tried to reccomend that he didn't. Not knowing too much about the MTX brand. I wasn't sure if they did something goofy like that. I have had too many different amps that failed prematurely because I ran em too hard. I don't care if the amp is rated at 2 ohms or not. If you run it at two ohms, you are going to work it hard and it's gonna run hot. Two votes now for running it normally. By this I mean hook each sub to their respective channels.
Old Jul 10, 2003 | 12:42 AM
  #27
thanks guys one last q i am kinda understanding more now but the way my box is the 2 12s sit in it and both neg and both pos run to one neg and one pos terminal outside the box should i just bridge it w/ the 2 channels or ?
Old Jul 10, 2003 | 12:44 AM
  #28
DelSoto's Avatar
Am I the only one reading this??
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
cmdeshon
Jan 4, 2015 11:15 AM
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
