wire length question
Old Sep 15, 2002 | 03:21 PM
PaulN64's Avatar
for those who have ran brand new speaker wires to all four speaker holes (from a trunk mounted amp), how much wires did you use? When I get my car back from the shop, I'm going to run brand new wires (since I'm still using some stock wires).
Old Sep 15, 2002 | 08:30 PM
97FormulaWS-6's Avatar
I have my 4 ch amp mounted under the PS seat, I'm wired for the rear speakers, and double run for the fronts (2 pair to each side, 1 for Tweeter, and 1 for Driver) and I used about 70', I'd say to the rear with all the wires would be about 100' dependsing on how you run it. I personally get all mine together and they run as a bundle to the amp. I could have probably used less wires, but I ran them the "neatest" way i could.
Mike
Old Sep 15, 2002 | 10:00 PM
PaulN64's Avatar
Mike
here's the plan. I want to run new wires to each of the speaker hole, as I said before. But all the xovers are going to be moved. The rear speakers' xovers are already back there, and the front xovers are going behind the side foot panel.
Old Sep 16, 2002 | 08:07 AM
Head Hunter's Avatar
Wink
I used about 60' or so of wire.
That is with the amp mounted on the back deck and runing speaker wire to the rears and to crossovers in the same place as you.
If you are in the trunk it will be another 15 foot or so.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
oldschool
Feb 9, 2016 09:21 PM
lbrowne
Nov 13, 2011 04:25 PM
GigaMp3z
Feb 20, 2003 02:57 PM
$hawn
Aug 28, 2002 09:09 AM
