will my sub bass get cut with stock monsoon stereo
Old Sep 21, 2004 | 06:28 PM
D James's Avatar
I've noticed that with the stock monsoon the bass gets cut or diminishes with higher volume. I'm guessing so as not to blow the speakers or something, anyway if I hook up my sub to the stereo will this also hapen to the sub? I assume it would have to since I'd have to use the same speaker wire that cuts all the bass to begin with. I really wanted to keep the stock stereo so I could keep the stock CD changer, but the more I learn about the monsoon, the more i want to just throw in my Alpine. Is there any way to keep the bass from getting cut?
Old Sep 21, 2004 | 10:00 PM
BandDirector Blk98ZM6's Avatar
Re: will my sub bass get cut with stock monsoon stereo
Tap the wires BEFORE the Monsoon amp or get a PAC OEM-1 to do it for you. I kept the Monsoon HU and changer and replaced everthing else.
Check out this thread for more info:
http://www.ls1.com/forums/showthread.php?t=48092
You can check out my system at the link in my sig.
Old Sep 22, 2004 | 06:29 AM
D James's Avatar
Oh are you saying its the amp that cuts the bass? I thought it was the headunit that cuts it. I am plannin on ripping that thing out and placing my good amp in its place, so then I guess I wouldn't have a problem if i did it this way?
Old Sep 23, 2004 | 04:39 PM
Correct, it's the Monsoon amp that has the speakers x-over...the HU is just a standard 4 channel GM HU.
Old Sep 24, 2004 | 01:26 AM
D James's Avatar
OK thanks
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
SVT3852
Aug 16, 2002 03:35 PM
Paulberg
Jul 26, 2002 11:35 AM
u8dusst
Jul 25, 2002 09:07 PM
