Will the 6.5 Componets POLK MOMO's fit in our cars?
wasnt sure if they work or not? i want to know if anyone knows that this particular brand will work for sure, not by just seeing the size, cause i've never heard anyone using this..
thanks guys
chesee48@aol.com
thanks guys
chesee48@aol.com
Yes. I put a set in a friends Trans Am a little while ago. You cant use the stock plastic mounting piece but what we did was trace out that plastic piece onto 1/4" MDF, cut it out, made the correct notch's in it and drilled out the wood in the same places the stock plastic piece mounted to and put it in. You will want to get some weather stripping or whatnot to help seal the MDF around the door (not like it matters to much with all the holes in the door itself). And they sound good.
94z28jbw
Sep 8, 2002 03:22 PM
racer08
Jul 23, 2002 05:43 PM
