Will a 2004 OEM Hummer Cd changer work in my 2000 Fbody?
Old Feb 25, 2007 | 10:05 AM
Coasterkid's Avatar
I have an oppurtunity to pick up a 12 disk CD changer from a 2004 hummer for very reasonable. I'm not sure it has the 10 pin plug in..... I was wondering if any of you stereo people knew if the stock 12 disk CD changer from a 2004 hummer will plug into my stereo. Thanks again.
Old Feb 25, 2007 | 06:42 PM
PentaVolvo's Avatar
nope... no way to make it work, the stereos in newer gm cars rely on a special signal from the computer to work
Old Feb 27, 2007 | 07:01 AM
LS1 RULZ's Avatar
The factory HU may have warning buzzers and things like that but providing the Hummer's CD changer can be mounted horizontally and is compatible with the changer harness in your Camaro you should be OK. Truck changers are made to be mounted in the vertical position only where the changer in an F-Body is meant to be mounted horizontally. The factory changers don't have adjustable suspensions for the CD transport mechanism like after-market changers do.
Brake_L8
Jan 20, 2015 09:44 AM
bsmith
Aug 23, 2002 04:17 PM
ChrisFrez
Aug 12, 2002 11:50 AM
My94RedZ28A4
Aug 11, 2002 10:04 PM
Paulberg
Jul 26, 2002 11:35 AM
