Why is my amp shutting off?
I have a RF Punch 250 supplying power to the JL Stealth box 10w3. When I'm cruisin' along for a while with the volume up the amp overheats and shuts off for 1-2 minutes. I was under the impression that these 2 would work perfect together? Do I need a bigger amp?
What impedance are the VC's of your JL sub? Is your amp bridged? I don't know anything about the amp from just a model number.
You either have a load that is too low for your amp to handle causing it to go into thermal protection mode or you have your amp's gain set way too high.
