Where to run power wire thru??
Theres gotta be an opening somewhere thru the firewall, i'm sure someone knows exactly where it is, any help would be great, thanx.
Also with all looping and what not would 20 ft of power cable be enough to run from the front of the car to the back?
The gromet (hole) is located on the passenger side of the car underneath the PCM. It's easier to remove some panals from the inside and then feed it through to the outside. Unless you got really small hands/arms, you're going to have to move the PCM out of the way to feed it through from the engine bay. Take a flashlight and shine it behind the PCM so you get an idea of where it's at so you can find it easier from the inside.
Yes, 20 ft should be sufficient to make it through the car.
Thanx guys... Moving the PCM is no problem for me, the other question is will the wiring (10 ga) run underneath the carpet if the seat is removed and not bulge out thru the carpet basically i'm asking if the wiring will reach a point where it will be exposed or is it possible to hide it all the way thru to the back? Also where would be a good short location in the back for a ground? Thanx again...
Mine is ground to the chasis on the pass. wheel well using a Stinger grounding apparatus. There are plenty of bolts in the back that will work just fine if you're not **** like me.
So there are bolts on the right side in the back where the spare tire used to be? I'm gonna be using a 250 watt amp probably won't even be bridging it so i'm not to worried about the wire ga.
I managed to hide 1/0 gauge under my carpet and it not show...
I can't see it anyway...
My sig has a link to my cardomain page with a fewpics of the cable run, you can see where the factory grommet is and everything.
Be careful, after I put mine through the firewall and installed everything my car would not start. And when it did it would run for like 2 seconds. The next morning I cranked it over and got it to run but had trouble in keeping it to run. I don't know what I hit or messed up, but just be careful going through the hole by the PCM!
But i'll take that warning seriously.
Well if you took the PCM out maybe the connectors weren't in all the way?
hey i'm sure everyone here will disagree with me.. but i'm a lazy *** and i didnt feel like feeding wire through my firewall and hiding it all the way to the back.. instead i soldered into the wires that were running to the stock bose amp for the rear subwoofer.. there was also a already remoted power line and 3 grounds back there too. i'm running a single 10" sub in a ported enclosure with a 400 watt amp bridged and it sounds awesome.. i dunno just fillin you in on my lil ryan-riggin job :-D
wow how strange last night it caught fire in the garage and took my house down with it haha jk.. i dont think its that risky is it i mean afterall it is on a fuse.. i just dont see much difference as long as im getting good power, good ground, and clean sound inputs.. i bow down to you that spend the time to rip your cars apart and make fiberglass enclosures etc etc
but i just wanted a lil more bass and only wanted to spend about an hour to get it.
Running a power wire that is too small causes increased heat on the wire. If the wire gets too hot, it melts, if it melts, it can short, if it shorts, it sparks, if it sparks it can cause a fire...
Not saying that it will happen, but it could.
sleeperZ96BT
Jul 24, 2002 11:28 AM
